Full Version: Wrong Aspect Ratio Germany TV Channel Disney HD and Deluxe Music HD only with TVHeade
Hi,I am using the shield with Kodi and TVHeadend for Live TV. On 2 Channels the aspect Ratio is not correct. When I deactivate Hardware decoding feature of shield all is fine. But then I cannot Play 4k Content. When I use DVBViewer as Backend there is no problem (same problem).Any suggestion what I can do ? You can see it on picture. This has to be 16:9. And I really checked all other options. The Channel has Resolution of 1280X1080. All Other channels are fine.
The Hardware Decoder seems to do here something wrong ?additional Info (copy)The TV is a LG 65b6D with native resolution of 3840x2160 (4K). Other Channels are not affected. Here in Germany only DeluxeMusic HD (1280x1080) 16:9 and Disney Channel HD (1440x1080) 16:9. Other 4:3 / 16:9 channels are fine.Same Kodi Version played with Raspberry 3 shows no problem with both Channels.Kodi Resolution is 3840x2160p and Shield Setup 3840x2160.If I disable hardwaredecoding on Shield both Channels are played correct.
But then I lose the ability to Play 4K Films.
If I scale Down the Resolution 1920x1080 the problem still exist
Here the Debug log https://paste.ubuntu.com/26237176/
IMAGE:
https://ibb.co/debYaR
Tested with Kodi 16/17.6/18alpha nightly 23.12
does not work with dvbviewer backend corrected.
Your image is not working: 'Access denied. You are not authorized to view this page.'
Upload images to https://imgur.com or https://imgbb.com and link the images here, not the webpages.
Sorry ... updated in first post
