Full Version: Internal SQL error searching for new unread posts
Keep on getting the below error since some days:
Quote:MyBB has experienced an internal SQL error and cannot continue.
SQL Error:1406 - Data too long for column 'ipaddress' at row 1
Query:
INSERT INTO mybb_searchlog (`sid`,`uid`,`dateline`,`ipaddress`,`threads`,`posts`,`resulttype`,`querycache`,`keywords`) VALUES (...)
Grateful if someone could fix that.
Luigi
might be related to you using ipv6...
will have a look if there's a fix
@lcapriotti when does this error happen ?
i have a feeling 'View Unread Posts' triggers it, but i need you to confirm
correct, that's what I do normally to keep me abreast of the latest trends...
ok, should be fixed now
Brilliant, kudos!
