Full Version: Control via Json refused
I try to connect and control Kodi via Json on port 9090.
My program is on the same system.
If I enable only "Allow programs on this system to control" I get always Error 10061 Connection refused.
Only if I enable "Allow programs on other systems to control Kodi " I can connet and control Kodi.
I tried local IP, Localhost and 127.0.0.1.
Is there special address I have to use ?
Log?
Unfortunately there is nothing in the log.
I also enabled JSON module logging.
Is there a extended logging available which I have to enable via xml  ?
I tried the logging with1.2.3 advancedsettings.xml for everything
http://kodi.wiki/view/Log_file/Advanced#...ttings.xml
Bu nothing inside the log containing Serverport 9090 or refused connection.
