Full Version: RSS Feeds
Hi. I am trying to set up some RSS feeds as music/audio sources.  So far, a few have worked and a few haven't.
*I replaced "http(s)" with "rss" in all of these addresses
Worked:
http://feed.thisamericanlife.org/talpodcast
http://feeds.wnyc.org/onthemedia
Didn't work:
https://wdet-rss.streamguys1.com/Music/ADEM/adem.xml
This one looked like it worked.  It successfully added as a source and showed some picture art and 4 episodes to choose from.  But when you try to select one, it doesn't load.
So which feeds can be added?  And is there a way to make feeds like ADEM work in Kodi?  Or do the providers need to offer them in a different format for it to work on Kodi?
thanks
I am using Kodi 17.6.
Didn't even know this was possible!
Maybe someone could update the wiki with a guide for RSS?
(2017-12-28, 12:36)docwra Wrote: [ -> ]Didn't even know this was possible!
 Yeah I just found out about it myself.  I thought it was a pretty cool feature.  I was trying to figure out the best way to use my audio system to listen to some podcasts that typically launch in a player in the browser.
Here's what the wiki has so far for RSS media sources:
http://kodi.wiki/view/RSS_media_source
Here's another feed that I would like to have in Kodi.  I can get it to work in Feeder (www.feeder.co) but the media won't start playing with Kodi.
https://a2ctn.viebit.com/rss.xml
When I add the source with "rss" in place of "https" then it will show a list of episodes.  But when I select one of the episodes, Kodi does not respond.
Hey everyone.  I am trying again to make this work...
One difference that I have noticed is that the sources where this works properly have files that are .mp3.  The one where I can't get it to work uses AAC files.  I have tried downloading some of the AAC files onto my machine and those play properly.  But when I try to stream the same file, it doesn't work.  I saved some logs for various conditions:
successful AAC playback of a file stored on my machine
https://paste.kodi.tv/uduvubadec.kodi
successful stream of an MP3 podcast
https://paste.kodi.tv/uxabugedin.kodi
unsuccessful stream of an AAC podcast
https://paste.kodi.tv/yodijoqeyi.kodi
