Full Version: InputStream Adaptive: Decrypt Sample returns failure!
I got Kodi 18 nightly and finally the netflix plugin running. Everything is fine, except when i enable HEVC; at resolutions bigger than 480p i only hear the audio, while the video is frozen.
Without HEVC, videos work fine up to 1080p. However i'd still prefer getting HEVC running.
log after changing the resolution from 480p to 1080p:
01:31:10.642 T:139772460412416  NOTICE: GL: Selecting YUV 2 RGB shader
01:31:10.645 T:139772460412416  NOTICE: GL: NPOT texture support detected
01:31:10.645 T:139772460412416  NOTICE: GL: Using GL_ARB_pixel_buffer_object
01:31:10.645 T:139772460412416  NOTICE: Using GL_TEXTURE_2D
01:31:13.117 T:139770020480768  NOTICE: Closing stream player 2
01:31:13.118 T:139770020480768  NOTICE: waiting for video thread to exit
01:31:13.161 T:139769993467648  NOTICE: thread end: video_thread
01:31:13.161 T:139770020480768  NOTICE: deleting video codec
01:31:13.162 T:139770020480768  NOTICE: Opening stream: 7 source: 256
01:31:13.227 T:139770020480768  NOTICE: Creating video codec with codec id: 174
01:31:13.227 T:139770020480768  NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: HEVC (High Efficiency Video Coding)
01:31:13.227 T:139770020480768  NOTICE: Creating video thread
01:31:13.231 T:139769732900608  NOTICE: running thread: video_thread
01:31:13.304 T:139770020480768   ERROR: AddOnLog: InputStream Adaptive: Decrypt Sample returns failure!
I've been hours on this without any progress. Any hints what I could try?
1) That is not a full and probably not debug-enabled kodi.log
2) Do not paste logs/snippets directly onto our forum. Use Pastebin.com or some similar text upload website to not burden our own forum.
Ah, yes. That resolved the issue, thank you.
