Full Version: EPG Grabber Channels not listed
Hi. I have the following setup:
Server : Fedora 27 running Tvheadend 4.2.4
Clients : LibreELEC 8.2.2 running pvr.hts 3.4.27.1
The server has a couple of DVB-T2 cards in it, Tvheadend is configured to use them and everything appears to work perfectly from the clients.
I also have Sky and to save me manually switching from one EPG to another just to see what was on, I've manually added some of the Sky channels to Tvheadend using WebGrab+Plus (V2.1).
Using the Tvheadend Web UI I can see the channels:
https://pasteboard.co/H09h7sY.png
and the listings show up in the EPG:
https://pasteboard.co/H09hxnK.png
However, neither the channels or the listings are available from the clients.
Does anyone know any obvious reason why not?
I can supply a debug log if required, although I couldn't see any references to the EPG Grabber Channels when I enabled debugging.
Many thanks.
I've just tested this with an Android client and that doesn't see the channels / listings either, so I presume this is a server side issue. I have posted in their forum. This thread can be closed.
