since a while I have the priblem that every HD channal is marked as 3D.
I have disabled all 3D but it's stll the same...
Problem is, that changing the channal need more time cause playback "stops" two times before playing a channal...
any Idea where the problem could be?
thanks
sveni_lee
Kodi 17 or 18?
In Kodi 18 there are a few changes that need tweaking in the Skin xml.
So you need maybe an update of the Skin.
I've this with Kodi 17 and Kodi 18...
I really don't know where is the reason for that. I tested with two paortable istallation on my laptop plus
on my HTPC. All settings are the same.
Kodi 17 on Laptop no 3D (newer than on HTPC)
Kodi 17 on HTPS shows 3D
Kodi 18 on Laptop shows 3D
