Full Version: No sound on Kodi 17.6
I have been using kodi for a long time now, never had any issues with it but Now that i have update it to 17.6 i am unable to get any sound from any stream i am using the same tv (LG) for the android box from since I got the box i have tried everything thing to get the sound.I have gone through all the android box settings, gone through the kodi settings and pressed f8 f9 and f9 yet i was u able to get any sound. The android box that i am using is MXQ PRO 4K i have never had trouble with this box, this si the first time. I am very hopeful someone can provide me with a solution.
Many thanks
S P
The instructions are here... debug log (wiki)
1.Enable debugging in Settings>System Settings>Logging,
2.Restart Kodi
3.Replicate the problem.
If you are using the Advanced Method ensure you have correctly created and applied the advancedsettings.xml file.
In both instances, you should see the word DEBUG throughout the log.
Do NOT post your logs directly into the forum. Always use a paste site like pastebin.com. Post the link to your pasted log in the forum
