Full Version: Can't play from movie library
Hello,
This question should have been asked before but I couldn't find it...
1. I had USB HDD connected directly to Android TV box and had library set up and working.
2. I moved this HDD and connected it to USB port of NAS.
3. Cleaned library from menu. (Library completely cleaned, meaning I didn't see movie covers any more.)
4. I re-scanned all movies to library.
5. Movies showed up in the library but when I click it, nothing happens.
6. If I navigate to file, it will play.
7. I can play movies I saved after the move. (same HDD on NAS.)
8. I reset the box to factory setting, reinstalled Kodi, re-scanned movies but still not playing. (New ones play fine.)
Someone, please let me know how to fix this...
Thank you in advance for your support.
TJ
The instructions are here... debug log (wiki)
1.Enable debugging in Settings>System Settings>Logging,
2.Restart Kodi
3.Replicate the problem.
If you are using the Advanced Method ensure you have correctly created and applied the advancedsettings.xml file.
In both instances, you should see the word DEBUG throughout the log.
Do NOT post your logs directly into the forum. Always use a paste site like pastebin.com. Post the link to your pasted log in the forum
