Full Version: VS Code - Kodi Skin Reloader
For anybody who uses VS Code as your editor of choice for skinning, all 2 of us Smile then this extension will reload Kodi's skin on every file save. Grab it from the extension marketplace.
-update: Ability to set username and password for secure access to Kodi's web serve.
Do you have any plans to extend it? With some functions of the sublime dev kit? I would have a small wishlist Smile
(2019-09-04, 08:42)sualfred Wrote: [ -> ]Do you have any plans to extend it? With some functions of the sublime dev kit? I would have a small wishlist Smile
No plans at the moment, I just don't have the kind of time it would take Sad  I only needed a simple way to automatically reload Kodi's skin while developing. Which functions were you hoping for?
- Search for language string skin/addon
- Add string to language resource file of skin/addon
- execute command to Kodi (will be executed by script.toolbox Kodi addon) like "Runscript(bla)" or "activatewindow(bla)"
- get info label from command via JSONRPC (result will be returned by script.toolbox Kodi addon)
- directly jump to a include/variable by selecting and pressing a key combination
These are the most used functions on my end
