I'm trying to get the UPNP on the new xbox one app to find my computer. My other electronics (ie. iphone, ipad) are able to find it. I'm not sure if this has been set up or if it is a bug, but I wanted to make sure I was not doing something wrong.
In Alpha1 only NFS works.
You need to use WinNFSd
(2017-12-30, 00:45)shindou Wrote: [ -> ]Hi,
Please please you and everyone, READ this
https://kodi.tv/article/kodi-xbox-one
How can i use? I try and i cant do this work, dont mount my folder
Did you read the link posted by nickr just above your post ?? The answer is inside...
I mean How can i use NFS on Windows 10
(2017-12-30, 18:13)maker3 Wrote: [ -> ] (2017-12-30, 15:56)jeankrj Wrote: [ -> ]I mean How can i use NFS on Windows 10
I created quick tutorial
https://www.youtube.com/watch?v=LAr8mdvDp2A
Tanks!!
I try follow, but i got this message from powershell or cmd
Path format is incorrect.
Please use a full path such as C:\work
I Got it!! tyvm!
How can i share more than on local? cuz i have 2 HDs on media
and i need to let powershell windows open?
Thank you so much for this - got it working pretty good now !
sorry - do i need to do this every time i boot up the computer ?
(2017-12-30, 20:00)jeankrj Wrote: [ -> ]How can i share more than on local? cuz i have 2 HDs on media
I was wondering the exact same things
(2017-12-31, 03:17)dchabby Wrote: [ -> ]sorry - do i need to do this every time i boot up the computer ?
Yes, this is regular program. If it's closed, it isn't working.
If you want to do autostart, you can make rule in Task Scheduler. There is option to add parameters.
I have a mac computer so I can't use window programs very easily. Is there a way to set up NFS with mac? I've looked around but haven't been able to find it.
