Hi, just installed the latest Kodi libreelec build and have been really impressed until I tried playing some DVDs, all original. When I pop the DVD in the drive it runs ok, I can hear the music but the DVD navigation menu and the video remain blank.
I'm running on an intel core2 duo with 4gb ram and have an intel htpc motherboard with onboard intel hdmi chipset.
All other video works fine whether streaming or playing local files
The instructions are here...
debug log (wiki)
1.
Enable debugging in Settings>System Settings>Logging,
2.
Restart Kodi
3.
Replicate the problem.
If you are using the Advanced Method ensure you have correctly created and applied the advancedsettings.xml file.
In both instances, you should see the word
DEBUG throughout the log.
Do NOT post your logs directly into the forum. Always use a paste site like pastebin.com. Post the link to your pasted log in the forum
(2017-12-31, 00:25)Klojum Wrote: [ -> ]To receive meaningful assistance you will need to provide a full debug log.
The instructions are here... debug log (wiki)
1.Enable debugging in Settings>System Settings>Logging,
2.Restart Kodi
3.Replicate the problem.
In both instances, you should see the word DEBUG throughout the log.
Thanks but I managed to sort the issue out this morning. The fix for me was to set the MPEG2 hardware decoding option to OFF in the video playback settings. Obviously an issue with my Intel HDMI chipset and the linux driver support.
