Hi, I recently updated my librelec to latest version which also puts me on kodi 17.6 and now my progress bar has gone transparent and my paly pause icons are very small. I only ever use confluence cos i like simple and tried different skins to no avail so went to confluence 1080 but still no change. it seems like the new kodi build thing is doing it, any ideas guys, thanks
The instructions are here...
debug log (wiki)
1.
Enable debugging in Settings>System Settings>Logging,
2.
Restart Kodi
3.
Replicate the problem.
If you are using the Advanced Method ensure you have correctly created and applied the advancedsettings.xml file.
In both instances, you should see the word
DEBUG throughout the log.
Do NOT post your logs directly into the forum. Always use a paste site like pastebin.com. Post the link to your pasted log in the forum
if you are using a "build", then this is most likely messing up the skin (along with your entire installation, but that's a different story)
