Full Version: UWP App crashes on XO S after power off
Hi guys, this is my first post and I'd like to thank the devs that Kodi is finally (back) on Xbox.
I wanted to address an issue I encountered and I'm not sure if I'm doing something wrong.
I installed the Kodi App on my Xbox One S and setup Kodi with various settings and connected my NAS via ftp.
The scraper vor Fanart worked about right, only thing missing is the option to choose the language, i.e. german vor tvdb.
Once the video library was scanned, I was able to watch and all was working fine.
When I switched off my Box (which is running in energy safe mode) I couldn't start the Kodi App the next day.
It failed a trillion times, even when I moved the App on an external HDD.
I deinstalled and installed the App again and had to setup everything all over again.
When done, switched my Box off and the next day.....the App crashed again.
Does anyone experience the same, is there a work-around available ? Can the settings be saved ?
Would love to run the Kodi app again on xbox but hesitate to setup and lose all content again.
cheers,
andy
The instructions are here... debug log (wiki)
1.Enable debugging in Settings>System Settings>Logging,
2.Restart Kodi
3.Replicate the problem.
If you are using the Advanced Method ensure you have correctly created and applied the advancedsettings.xml file.
In both instances, you should see the word DEBUG throughout the log.
Do NOT post your logs directly into the forum. Always use a paste site like pastebin.com. Post the link to your pasted log in the forum
