Full Version: The TVDB scraper Not authaorised
Hi guys
I've just wiped my kodi and started fresh again and running into some problems getting the TV shows adding to the library.
I know my Files are named correctly as i've  never had an issue...I had to start fresh as i was having difficulty  upgrading so installed Kodi 17 from fresh
Looking at the logs and using the TV Scrapper link there is some authentication error...Which i'm lost about..i've sure i've never had to do that before
10:17:19.441 T:1424241568   DEBUG: CurlFile:TonguearseAndCorrectUrl() adding custom header option 'accept-language: en'
10:17:19.441 T:1424241568   DEBUG: CurlFile::Open(0x4f5330e8) https://api.thetvdb.com/search/series?na...Night%20Of
10:17:20.035 T:1424241568   DEBUG: Get: Using "UTF-8" charset for "https://api.thetvdb.com/search/series?name=The%20Night%20Of|Authorization=Bearer%20eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVCJ9.eyJleHAiOjE1MTUwNjEwMzksImlkIjoiS29kaSIsIm9yaWdfaWF0IjoxNTE0OTc0NjM5fQ.sIytosVTU2A1vq--szvOV7Uw3yWYpZc5fOKSkJ0rzbx_CwiWMUi7Cf6vUofKZ91p_LGq3za3oryQbyRKAg5fuX0vw3REb-KCwitkFvzHKSiCdCVFDLoOR3de6IVT8wQgovMCgbkBvca7VJKZbQ7USA5dHVjXK3pQqi5YNA9LvnrzVVwsAJovwYd1jqxy3ob8nMIVKLna-iTPOLC_XWvMp5iC-frwYaYnFXih9CyJI6gjzfXV3SmBlnikVAo7qS3Dappcs8PGXZYQjYgAfjRpcnAidNfzF3WQpvsVE4QGnCNURIuQHKbrvpVuAc-QyalSLxql3spwyCf_Sni9ThgmjA&accept-language=en"
10:17:20.059 T:1424241568   ERROR: Run: Unable to parse web site
10:17:20.061 T:1424241568   DEBUG: FindMovie: Searching for 'The Night Of' using The TVDB scraper (path: '/storage/.kodi/addons/metadata.tvdb.com', content: 'tvshows', version: '3.0.1')
10:17:20.063 T:1424241568   DEBUG: scraper: CreateSearchUrl returned <url post="yes" cache="auth.json">https://api.thetvdb.com/login?{"apikey":"439DFEBA9D3059C6"}|Content-Type=application/json</url>
10:17:20.069 T:1424241568   DEBUG: scraper: GetSearchResults returned <results><url function="GetSearchResultsAuth" cache="search-The%20Night%20Of-en.json">https://api.thetvdb.com/search/series?name=The%20Night%20Of|Authorization=Bearer%20eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVCJ9.eyJleHAiOjE1MTUwNjEwMzksImlkIjoiS29kaSIsIm9yaWdfaWF0IjoxNTE0OTc0NjM5fQ.sIytosVTU2A1vq--szvOV7Uw3yWYpZc5fOKSkJ0rzbx_CwiWMUi7Cf6vUofKZ91p_LGq3za3oryQbyRKAg5fuX0vw3REb-KCwitkFvzHKSiCdCVFDLoOR3de6IVT8wQgovMCgbkBvca7VJKZbQ7USA5dHVjXK3pQqi5YNA9LvnrzVVwsAJovwYd1jqxy3ob8nMIVKLna-iTPOLC_XWvMp5iC-frwYaYnFXih9CyJI6gjzfXV3SmBlnikVAo7qS3Dappcs8PGXZYQjYgAfjRpcnAidNfzF3WQpvsVE4QGnCNURIuQHKbrvpVuAc-QyalSLxql3spwyCf_Sni9ThgmjA&accept-language=en</url></results>
10:17:20.094 T:1424241568   ERROR: Run: Unable to parse web site
10:17:20.095 T:1424241568 WARNING: No information found for item 'nfs://192.168.0.84/TV/The Night Of/', it won't be added to the library.
by the way im using TVDB 3.0.1
Please provide the full debug log.
The instructions are here... debug log (wiki)
1.Enable debugging in Settings>System Settings>Logging,
2.Restart Kodi
3.Replicate the problem.
If you are using the Advanced Method ensure you have correctly created and applied the advancedsettings.xml file.
In both instances, you should see the word DEBUG throughout the log.
Do NOT post your logs directly into the forum. Always use a paste site like pastebin.com. Post the link to your pasted log in the forum
Cheers for the help...sorry i just got back to respond.
I changed the scrapper and it is now populating..however i'll get the debug logs up as i would like it to work using the standard one
