2018-01-03, 14:36
Hi guys, I am dealing with serious problem on my Kodi (17.3) running on RaspberryPi2.
I have working proxy server (Squid3 on Ubuntu) which I verified is working on my Windows PC - when I enebled proxy (ip on port 3128) I was able to reach geo blocked content live stream.
When I put in the exact same proxy settings into Kodi on my RaspberryPi2 it is not working properly - without proxy I get info content is blocked message, with proxy enabled I just get 1 second circle (like when loading) and nothing happened (no stream, no info about geo block, no error). I checked squid log and connection reached it, and there is no error (just http 200 and 206)
Then I tried to install kodi on my windows PC - verified stream is blocked. Then I put proxy settings and content was unblocked and playing without problem.
Because I see in the Kodi proxy settings also user name and password I configured my proxy to ask for credentials and added credentials to Kodi (proved working in the PC browser again) - no change on Rasp2, stream did not start without any error. When I addded credentials into Kodi installed on Windows stream was working well.
Do you know what could be wrong? did someone experience this? I would like to avoid use VPN as I expect proxy could be in theory faster and also I have proxy under my own maintenance so it´s beneficial for me. So I really want to go way with proxy
Many thanks for any helpful answers
