Can anyone tell me how to clear the cache on this box.I was told to go into settings and then other or more settings locate Kodi and select clear cache but unable to find clear cache.
I forgot to say I am running version 17.6 which I believe is the latest version
Kodi does not have a Clear cach setting in its GUI.
Which exact cache are you referring too?
Which OS is running your Kodi?
The instructions are here...
debug log (wiki)
1.
Enable debugging in Settings>System Settings>Logging,
2.
Restart Kodi
3.
Replicate the problem.
If you are using the Advanced Method ensure you have correctly created and applied the advancedsettings.xml file.
In both instances, you should see the word
DEBUG throughout the log.
Do NOT post your logs directly into the forum. Always use a paste site like pastebin.com. Post the link to your pasted log in the forum
And please do not start double posting your topic...
Apologies for that as am very new to this and still learning
I have now disconnected the box from the TV as it seems to be causing unnecessary problems and I have put the box back into it's original box which I still had.But thank's for the replies they were much appreciated.
