Full Version: XML Required to Access Channel Groups via a skin
I am modding the SkyQue skin for my own purposes. If you are familiar with that skin, you click 'TV Guide' and it takes you into a TV guide with all your available channels present. What I wish to do is add an extra window, so that 'TV Guide' then takes you into a new window that has different categories of channels. If you were to click 'Sport' for example you would get sport channels only.
I am not asking for general assistance in adding windows or settng up channel groups etc, but what I am asking for is, what is the correct parameters/options/syntax I would need to use to toggle between channel groups? The logic order here would be then:
1. I click on my new sport button.
2. The sport channel group is selected
3. I then activate my EPG window where only the sports channels are now displayed.
