Someone remind me what files and where they are located that I need to submit for crashes.
The OSXBMC Wiki doesn't have it, and I've spent 20 min try to find it in the forum and general XBMC wiki.
I know someone remembers this offhand.
Topfs2 Wrote:look like 2 cm over your thread
Sticky on osx forum.. http://forum.xbmc.org/showthread.php?tid=32228
this is the one /var/tmp/xbmc.log
Couldn't find the specifics in the sticky. Must had missed it. Still not sure where /var/tmp/xbmc.log is located though. Don't see it in spotlight or user data.
jeremymc7 Wrote:Couldn't find the specifics in the sticky. Must had missed it. Still not sure where /var/tmp/xbmc.log is located though. Don't see it in spotlight or user data.
you won't find it in spotlight.
Step 1:
open terminal
Step 2:
cd /var/tmp
Step 3:
open .
Step 4:
Step 5:
Profit!
bmfrosty Wrote:you won't find it in spotlight.
Step 1:
open terminal
Step 2:
cd /var/tmp
Step 3:
open .
Step 4:
Step 5:
Profit!
So step, four and five are what now? How do I see/copy the log out of terminal to somewhere that it's viewable in the GUI and can be attached/uploaded?
Thanks, some of us are just not terminal smart.
step 3 "open ." will open "/var/tmp" in finder. You will find xbmc.log in there
In finder:
Go->Go to Folder...
Type in /var/tmp
xbmc.log will be there
