2018-01-22, 20:22
2018-01-22, 22:27
2018-03-07, 22:54
I tried to install MediathekView Addon on my Kodi 17.3 version, but got this message in the logging file:
21:35:13.749 T:140703962261248 ERROR: CAddonInstallJob[plugin.video.mediathekview]: MD5 mismatch after download. Expected 0c4eb3d5358b807e45437ec0c3b95fda, was D41D8CD98F00B204E9800998ECF8427E
When trying to use the zip method, this messages appears:
21:38:05.341 T:140704833833024 ERROR: GetDirectory - Error getting addons://search/
21:38:05.341 T:140704833833024 ERROR: CGUIMediaWindow::GetDirectory(addons://search/) failed
21:38:25.343 T:140703998027520 ERROR: CCurlFile::FillBuffer - Failed: SSL connect error(35)
21:38:25.347 T:140703998027520 ERROR: CAddonInstallJob[script.module.defusedxml]: MD5 mismatch after download. Expected d5d517bfb6c5d6402ee7233bdb9ef684, was D41D8CD98F00B204E9800998ECF8427E
21:38:25.349 T:140703998027520 ERROR: CAddonInstallJob[plugin.video.mediathekview]: failed to install dependency script.module.defusedxml
21:42:55.417 T:140704281241344 ERROR: CCurlFile::FillBuffer - Failed: SSL connect error(35)
What runs wrong?
What runs wrong?
2018-07-29, 22:25
I have previously been using Unithek, but I found this addon to be better and more reliable.
Great work on it!
However, I have one problem. As I am not a native German speaker, it greatly helps with subtitles. On Unithek, this is not a problem and I can just turn it on or off if it is available. I have so far not managed to get subtitles working on MediathekView. Do you have any tips how to achieve this? @tuxpoldo
Great work on it!
2018-08-04, 21:51
This is pretty cool plug-in. Thank you for that!
Wondering if it is possible do an incremental DB update instead of the complete one?
2018-08-06, 13:32
2018-08-10, 19:05
Hi folks!
After a lot of time, a new release has finally come out. Enjoy!
v0.5.0 (2018-08-08):
- Download option was missing in the context menu of some movies
- Support for older MySQL and MariaDB Versions
- Downloaded update files are deleted immediately after import
- Possibility to play a show with subtitles either with "Play with subtitles" in the context menu or automatically if configured in the plugin settings (if "Autoplay with subtitles" is enabled in the settings, the context menu command is not shown since it makes no sense)
- Search history
- Faster directory listing of live streams
- Possibility to download a show as Movie or as Series Episode. This implies two different configurable download locations, a different file naming scheme and different types of NFO files created
- Three different NFO file creation modes (None, simple or extended)
- Automatic detection of season an episode if possible
- Improved download settings (download locations, filename confirmation)
- Fixed a bug that prevented the creation of the SQLite database on some systems
- More efficient database layout
- The mvupdate script has got some additional options: --force and --interval
- "Update On Start" initiates the update when the plugin is invoked by the user
- Display of database type and version in the log file
2018-08-11, 23:19
Thank you. After updating, nothing is working not even the DB update. I'll check the logs and hope it's just me.
2018-10-06, 18:10
Hi
strangewise I have the message:
17:06:48.333 T:1624240880 DEBUG: CAddonSettings[plugin.video.mediathekview]: loading setting definitions
17:06:48.333 T:1624240880 DEBUG: CAddonSettings[plugin.video.mediathekview]: trying to load setting definitions from old format...
17:06:48.336 T:1624240880 DEBUG: CAddonSettings[plugin.video.mediathekview]: loading setting values
17:07:03.340 T:1624240880 DEBUG: CAddonSettings[plugin.video.mediathekview]: loading setting definitions
17:07:03.340 T:1624240880 DEBUG: CAddonSettings[plugin.video.mediathekview]: trying to load setting definitions from old format...
17:07:03.342 T:1624240880 DEBUG: CAddonSettings[plugin.video.mediathekview]: loading setting values
17:07:03.343 T:1624240880 DEBUG: CAddonSettings[plugin.video.mediathekview]: loading setting definitions
17:07:03.343 T:1624240880 DEBUG: CAddonSettings[plugin.video.mediathekview]: trying to load setting definitions from old format...
17:07:03.345 T:1624240880 DEBUG: CAddonSettings[plugin.video.mediathekview]: loading setting values
17:07:03.346 T:1624240880 DEBUG: CSettingsManager: requested setting (downloadpath) was not found.
but where should I define a downloadpath?
Database is empty and internal?
2018-11-02, 00:12
Hi, thank you very much for your addon.
I did not find any option respectively a setting. (OSMC 345, Mediathekview 0.5.0)
Edit: I finally found the options myself. :-)
Regards
Quote:Download with subtitles and automatic NFO file generationreads like you can download movies to watch them offline. If I interpreted it correctly, could anyone explain to me how I can download a movie to disk and how I can choose the destination?
Regards
2018-12-09, 23:03
Hello everybody,
I have a nasty problem with a clean-installed Mediathekview under my Fire-TV 4K Stick Kodi-Setup:
When I click on "Datenbank aktualisieren" Kodi tells me that my DB is going to be updated in a few moments. MEdiathekview starts to ownload the "Filmliste-akt.gz", but after the download completes, nothing happens, the db is not going to be initially build or updated.
It seems that Mediathekview can't decompress the .gz-file:
22:17:27.714 T:18446744071768066336 NOTICE: [plugin.video.mediathekview-0.5.0:Updater]: Trying to decompress gz file...
22:17:43.174 T:18446744071768066336 ERROR: [plugin.video.mediathekview-0.5.0:Updater]: gz decompression failed: [Errno 22] Invalid argument
22:17:43.175 T:18446744071768066336 NOTICE: [plugin.video.mediathekview-0.5.0:Updater]: Return -1
22:17:43.175 T:18446744071768066336 NOTICE: [plugin.video.mediathekview-0.5.0:Updater]: Cleaning up downloads...
Is that problem known? What can I do to solve it?
Debug log here
Kind Regards,
Germeleon.
Debug log here
Kind Regards,
Germeleon.
2019-03-05, 13:40
it really seems that some people with FireTV 4K are affected by this problem. Unfortunately it was not possible to reproduce the problem on other platforms. The new version 0.6.0 that will be released as soon as the pull request for the Kodi Repo is accepted will add some additional debug information that may help in finding the cause of the problem. If you like, you may install the 0.6.0 version from the beta repository. See Issue #103 on GitHub.
2019-11-15, 00:58
(2019-03-05, 13:40)tuxpoldo Wrote: [ -> ]Hi,Hy,
i installed mediathekview on my FireTV 4k (Kodi 18.4)
It doesn't work. I got this error:
2019-11-14 22:58:39.705 T:32020 NOTICE: UDP: Listening on port 9777 (ipv6 : false)
2019-11-14 22:58:40.583 T:32017 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.IOError'>
Error Contents: [Errno 2] No usable temporary directory found in ['/tmp', '/var/tmp', '/usr/tmp', '/']
File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.mediathekview/service.py", line 29, in <module>
from resources.lib.service import MediathekViewService
File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.mediathekview/resources/lib/service.py", line 17, in <module>
from resources.lib.updater import MediathekViewUpdater
File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/plugin.video.mediathekview/resources/lib/updater.py", line 24, in <module>
import ijson
File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.module.ijson/lib/ijson/__init__.py", line 28, in <module>
backend = _default_backend()
File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.module.ijson/lib/ijson/__init__.py", line 24, in _default_backend
return importlib.import_module('ijson.backends.' + backend)
File "/home/jenkins/workspace/Android-ARM-Leia/tools/depends/xbmc-depends/arm-linux-androideabi-21-release/lib/python2.7/importlib/__init__.py", line 37, in import_module
File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.module.ijson/lib/ijson/backends/yajl2.py", line 12, in <module>
yajl = backends.find_yajl_ctypes(2)
File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.module.ijson/lib/ijson/backends/__init__.py", line 34, in find_yajl_ctypes
so_name = util.find_library('yajl')
File "/home/jenkins/workspace/Android-ARM-Leia/tools/depends/xbmc-depends/arm-linux-androideabi-21-release/lib/python2.7/ctypes/util.py", line 274, in find_library
File "/home/jenkins/workspace/Android-ARM-Leia/tools/depends/xbmc-depends/arm-linux-androideabi-21-release/lib/python2.7/ctypes/util.py", line 99, in _findLib_gcc
File "/home/jenkins/workspace/Android-ARM-Leia/tools/depends/xbmc-depends/arm-linux-androideabi-21-release/lib/python2.7/tempfile.py", line 463, in NamedTemporaryFile
File "/home/jenkins/workspace/Android-ARM-Leia/tools/depends/xbmc-depends/arm-linux-androideabi-21-release/lib/python2.7/tempfile.py", line 275, in gettempdir
File "/home/jenkins/workspace/Android-ARM-Leia/tools/depends/xbmc-depends/arm-linux-androideabi-21-release/lib/python2.7/tempfile.py", line 217, in _get_default_tempdir
IOError: [Errno 2] No usable temporary directory found in ['/tmp', '/var/tmp', '/usr/tmp', '/']
What's wrong? What can i do?
