2018-01-09, 13:39
Hello,
I have a NAS model QNAP TS-453Bmini with KODI 17.6. On the NAS I have a file folder called "Multimedia" in which I have several videos.
I am trying to generate the library but I can't. I currently have this screen:
When entering Enter files section, the Multimedia folder appears, but it only allows me to browse through the contents and execute them, but it does not give me the option to select the folder as the library source.
On the other hand, in the Videos section, the Multimedia folder appears again. But I also do not see how to create the library from it.
Finally, entering in the Files category of the previous image ...
I try to add videos (Add videos ...) and then select the Browse option I give with the following screen where I do not know where to select the "Multimedia" videos folder
Definetly, I can't generate the content library. I don't know what I'm doing wrong or if I'm not using the right options. Some help?
Thank you very much in advance.
