Has anyone experienced similar movies is not working, for any movie that I tried same set of similar movies displayed. Could there be a setting that I need to initiate to get this function to work.
Update to the latest version of Skin Helper Widgets (1.0.37)
I just update, still it don't resolved the issue, also the cast didn't function, if for instance, I click actor I expect all related movies to display but it won't . If change skin to eustuary or confluence actor related movies displayed. Any suggestions
Ok, I shall pull a log tonight and post thanks
Thanks for posting the debug log. I'm not able to replicate the issue on my computer, but I'll keep reviewing it to find the cause of the bug.
I also updated Skin Helper Widgets again so the most current version is 1.0.38. It contains improvements which may help, so if you haven't updated yet, please do and see if it's fixed. Otherwise, I'll keep looking for a solution :)
Thanks for looking into the issue, I update tonight and keep U posted with new log, strange the cast movies works fine with Kodi default skin, I will take a log if would help.
Did you try to erase and recreate the database?
I never got this to work, I tried every possible settings I could think of nothing seems to work. Let me know if U get lucky
