2018-01-10, 01:23
Hi All
Newbie here, so I have run a Mede8er on my TV's for the last 10 years, and was happy with that so never looked for anything else, unfortunately the support has dropped off, after searching online i came across Kodi. Used to have the Mede8er plugged into TV and a hardrive plugged into Mede8er.
Downloaded Kodi on my Sony TV from the Play Store App on the TV, linked up my external hardrive (externally powered) to my tv direct through usb, started adding set content to videos, day 1 added movies, day 2 added series, noticed on Day 2 that the movies would not play from the movie folder, they played the day before. The metadata comes up but Kodi says the file no longer exists would i like to remove it from the library. But if i go through files while on Kodi, it plays the movie. What am i doing wrong? Any help appreciated, I did try searching.
I am just using Kodi to play movies i have on my external hardrive, not for streaming yet. Is that the best set up, to go direct to TV as well?
