Full Version: PVR Simple SQL Client w/ Recording
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16
How can I try the windows version please? Had this a long time back and it was great๐Ÿ˜๐Ÿ˜
@el_gonz87
work great on ,windows,libreelec & coreelec ()
thanks........
(2020-10-06, 23:44)Atamans Wrote: [ -> ]@el_gonz87
thanks........
Hi man.. Could you please share this addon for KODI coreelec ? thank you so much!
(2020-11-19, 04:06)Atamans Wrote: [ -> ]https://github.com/gonzalo-hvega/pvr.sql/releases
wow. thanks
thanks........
hi againe.
in CoreELEC can u but record multiple channels same time ? or just one?
and if some channel recording, can u open some other channel to watch some other channel while other recording?
I have problem. if i start recording some channel, then if i open same time(while recording on), aome other channel, i mostly see black screen with audio.
but sometimes even no audio, just not opening :/
and when i end this recording, then all starts againe immediatly ana i already dont know what to do.
im using x96max plus 4gb with coreelec, coreelec is in sd card. maybe someone had such problem and can help me?
strange.. but this happens only with coreelec
when i try same in android(with same android tv box), then i can record multiple channels and watch another channel same time, all works as need..
If someone compiled this to android, please can you share this with me ? Im ok with any kodi versions
will this run on Kodi 19 ?
Wo finde ich die android version zum downloaden?
Danke
How can I try the android version please?
