Full Version: PVR Simple SQL Client w/ Recording
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16
(2018-10-19, 18:57)Apeiron Wrote: [ -> ]
(2018-10-19, 05:10)el_gonz87 Wrote: [ -> ]
(2018-10-19, 05:03)Apeiron Wrote: [ -> ] Can I test Linux x64 on NUC5i3?
Nice job, mate!
 Sure, but I need to be able to send you a PM. Can you activate PM on your account so I can send you file/details.
Also, not familiar with NUC5i3 architecture, so hopefully it will work with my x64 compiled Linux version using an ASUS Laptop.
Done!
 Great! Sent u the details.
(2018-10-19, 03:34)el_gonz87 Wrote: [ -> ]
(2018-10-16, 14:57)grundam Wrote: [ -> ]This will be amazing, looking forward to a Windows version for sure!
(2018-10-19, 01:25)capncrunch Wrote: [ -> ]Can I test Windows & Android? On Android I would like to test on Nvidia Shield.
Thanks,
I've sent you both an e-mail with the DLL compiled for windows and instructions.
Appreciate your help!
Going to try and tackle Android next.
I received an error about shared dll not found i looked at logs and got this.
21:11:42.346 T:18640   ERROR: XFILE::CDirectory::GetDirectory - Error getting addons://all/
21:11:44.218 T:18640   ERROR: XFILE::CDirectory::GetDirectory - Error getting
21:48:38.802 T:27312   ERROR: Previous line repeats 2 times.
21:48:38.802 T:27312   ERROR: Win32DllLoader::Load: Failed to load "C:\Program Files (x86)\Kodi\addons\pvr.iptvsimple\pvr.iptvsimple.dll" with error 126: "The specified module could not be found.
21:48:42.592 T:27312   ERROR: PVR::CPVRClients::UpdateAddons - failed to create add-on PVR IPTV Simple Client, status = 6
i verified the dll is in that directory.
Thanks,
21:56:30.793 T:34912   ERROR: XFILE::CDirectory::GetDirectory - Error getting
21:56:58.413 T:19060   ERROR: Previous line repeats 2 times.
21:56:58.413 T:19060   ERROR: Win32DllLoader::Load: Failed to load "C:\Program Files (x86)\Kodi\addons\pvr.iptvsimple\pvr.iptvsimple.dll" with error 126: "The specified module could not be found.
21:57:04.647 T:19060   ERROR: PVR::CPVRClients::UpdateAddons - failed to create add-on PVR IPTV Simple Client, status = 6
What’s your OS and Kodi version?
(2018-10-20, 05:11)el_gonz87 Wrote: [ -> ]What’s your OS and Kodi version?
 Windows 10 and 17.6
 Am i doing something wrong the stock iptvsimple works fine I then remove the stock files out of the folder and I put your files in and restarted kodi. Then i get that error after trying to run it. If I remove your files and put the stock files back in that folder it all works again.
Running the new version. Here is what I noticed.
Logo still not on recording (Not sure if it is supposed to be fix yet)
Recording padding not being respected in the start or end
Channel groups are missing (present in the regular Simple Client)
Some recordings don't show until kodi restart
Still getting some recordings that randomly error
https://pastebin.com/98qeGqJz
(2018-10-20, 16:20)capncrunch Wrote: [ -> ]
Do you have windows store Kodi installed or did you use installer and it installed to Program Files?
Will test again in my VM, maybe my program requires a c++ redistribution. Willl check tonight.
@MrGenius1
The forum moderators have determined that Banned_addons (wiki) are present on your system. To receive assistance here, these banned items must be removed. If a clean log is not submitted within 3 days, then the relevant post(s) will be removed after this time.
(2018-10-21, 00:14)Karellen Wrote: [ -> ]@MrGenius1
 Logs have been cleaned
(2018-10-17, 21:44)el_gonz87 Wrote: [ -> ]
 I've got windows compiled to a DLL and loads just fine, however when FFMPEG gets called a terminal window pops up and libexecstream fails to capture the STDOUT pipe.
Will have to do some more digging, I think this is the only issue so far.
Meanwhile LINUX beta testing has gone live.
Thanks to those willing to participate.
 Hey. I'm more than happy to test it under MacOS, both 10.13 and 10.14 if you send me a compiled version or share GH repo.
Hi, I can test Linux 64 bit & Android versions.
@el_gonz87  Is there a new version coming soon for testing since this one will time out soon?
I will try to have one available next week, had to travel for a conference and have not been able to work on it this week.
Look for one Tuesday of next week, hopefully fixing Windows install.
@MrGenius1, can you download your M3U and remove https, then send it to me via PM so that I can look into channel groups? Want to get an understanding of why the channel groups would not load (they work on mine).
i would like to be tester of ANDROID (MiBox 3). I tried compile my own kodi apk but when modify txt for use your github i get a error while compile your addon. I am using versión of kodi of today and your code is from 2 months, maybe you made some modification and no work for this.
This is the log: kaqoxahobe.kodi (paste)
If it's my fault please make me know... thanks and contact me PM for your APK.
Long live to your IPTVSimple Recording is the kick that need KODI.
