Hi Ronie
Firstly, thanks for making this very useful script better and more easy to skin.
Since you are in process of re-coding the whole thing, is it possible to add an option in context menu for adding any search results item to Kodi Favorites ?.
This was a Bello user request since the old version and i think it will be a very useful addition.
Cheers
Nessus
sure, will add it to the next version.
Great
Thanks Ronie
ronie - Started skinning this for Leia. So much easier!
One thing I noticed is the back button doesn't work as expected when going inside Tvshows/Seasons/Artists/Albums. If you click on a tvshow and then press back it closes global search rather than going back up one level. Not sure if there is a solution for this?
afaik there's no easy way to provide back functionallity for script created directory structures.
I had a feeling that was the case.
Either way, fantastic work! The changes have made skinning a breeze.
Love the new version. Thanks. I only miss the option to display all result at once with different list containers. This limits the skinning options
ronie
Hi, I tried to get the new version of global search but the link not working!
I have version 7.4.7, How can I open it in custom button, I tiried this but didn't work:
<onclick>XBMC.Runscript(special://home/addons/script.globalsearch/default.py)</onclick>
what is the proper way to do it?
Thanks for all
xml:
<onclick>RunScript(script.globalsearch)</onclick>
Thanks, Solved!
But I tried to look for new version of globalsearch addon v8.0.2 but didn't find!
Is it still available?
it's in the addon repo. the new version is only available for kodi leia.
Hi Ronie, Could you please share the link to the repo, I would like to download the new repo.
(2018-11-01, 15:42)t123thomas Wrote: [ -> ]Hi Ronie, Could you please share the link to the repo, I would like to download the new repo.
Its already in the kodi repo. [Leia]
Isn't it for you?
I have download the addon, but my surprised is that the search and play works fine in the Kodi/Windows 10 but it only search but not able to play in Kodi/Libreelec. any one has similar experience.
ronie I can't get fanart to show when in episodes.
