2018-01-11, 12:49
Hi all,
I have kodi 17.6 installed and set it up with a PVR backend.
I was having a problems with my PVR EPG data being fulled populated than randomly going blank.
After a lot of troubleshooting, I rebuilt Kodi from Scratch with default theme and tested the following
1. Test Kodi 17.6 with TVheadend back end and - TVHD Client
2. Test Kodi 17.6 with NextPVR back end and - NextPVR Client
on both setups I ran into the problem where the OSD Mini Guide does not always populate the EPG data.
I also noticed that as soon as I bring up the OSD Mini guide, when i go back to my EPG guide it is blank
The only way to fix this is to clear the clear live TV data in settings and not use the OSD Mini guide.
See a couple of screenshots.
Not sure if this is a known issue or if anyone else has experienced this problem
https://www.dropbox.com/s/uyo38ozsm7t8txo/screenshot002.png
https://www.dropbox.com/s/2eo2s4f05t63w8f/screenshot001.png
There was also another thread that picked this up. From my testing I assume this is across all Clients / back end configurations
https://forum.kodi.tv/showthread.php?tid=320299
Any thoughts would be great, be good to see if this could be fixed
