Ok i've done some researching but can't find this.. I downloaded a script and don't like it (found something better) so how do I remove the one I don't want? Do I have to do that via ftp or can I do it from the controller? Also I'm VERY new to scripts well even xbmc so anyone recommend some must haves? I read that there is like an internet browser but couldnt fine it-whats it called? Thanks!
Since i CAN'T edit my post i found out how to delete it (q file) and that the box only has 64 mb ram so browser is a no go. SOOO what scripts would you all recommend? right now all i have is a youtube, apple movie trailers, t33ch ugrader, and itunes radio. I have no cable so any type of tv, radio, any cool stuff would be recommeded! Thanks again
you go to the filemanager, then navigate to Q:\scripts .. move cursor over the scripts folder, press white button (title on remote) and choose delete.
My xbox hasn't got a Q Drive and I install scripts in E:/Apps/XBMC/Scripts.
Is this normal? Is it a problem? If so, how do I solve it? Thanks.
