2018-01-15, 19:17
Not each time, but mostly all the time, when I try to launch a video 2 things arrive:
1) the video is not really launched: the time counter start in the bottom screen, but the video is not viewable. If I'm able to access the bottom and clic on the "full screen", a blank screen appear
2) a blank screen arrive directly and after a while, the prompt arrive and a log file is created in the home directory. (an example here: Kodi Log File )
In the screen I have :
I search for many different solution without success (for example validate that some /dev are owned by video group and my user in the video group).
If someone is able to help ...
Thanks in advance.
Quote:Code:Exception SystemExit in <function _remove at 0x61a05430> ignored
Exception SystemExit in <function _remove at 0x618c8bf0> ignored
Exception SystemExit in <function _remove at 0x5eedf6b0> ignored
eglCreateImageKHR: failed to create image for buffer 0x61 target 12465 error 0x300c
eglCreateImageKHR: failed to create image for buffer 0x63 target 12465 error 0x300c
eglCreateImageKHR: failed to create image for buffer 0x65 target 12465 error 0x300c
eglCreateImageKHR: failed to create image for buffer 0x67 target 12465 error 0x300c
eglCreateImageKHR: failed to create image for buffer 0x69 target 12465 error 0x300c
eglCreateImageKHR: failed to create image for buffer 0x47 target 12465 error 0x300c
eglCreateImageKHR: failed to create image for buffer 0x5a target 12465 error 0x300c
usrvcsm: [vcsm_malloc_cache]: [1442][mmal_vc_port buffer]: ioctl mem-alloc FAILED [-1] (hdl: 0)
usrvcsm: [vcsm_vc_hdl_from_hdl]: [1442]: invalid device or handle!
usrvcsm: [vcsm_lock]: [1442]: invalid device or invalid handle!
mmal: mmal_vc_shm_alloc: could not allocate 1048576 bytes of shared memory (handle 0)
mmal: mmal_vc_port_payload_alloc: vc.ril.video_decode:in:0(MP4V): failed to allocate 1048576 bytes of shared memory
mmal: mmal_pool_initialise_buffer_headers: failed to allocate payload 0/2
usrvcsm: [vcsm_malloc_cache]: [1442][CGPUMEM]: ioctl mem-alloc FAILED [-1] (hdl: 0)
Aborted (core dumped)
Crash report available at /home/pi/kodi_crashlog-20180115_165529.log
Thanks in advance.
