Does anyone have any suggestion on what settings can rectify this problem, Im using firetv however while watching sports, Cricket balls, Tennis balls footballs all move with this jittery action tried numerous Kodi settings but no luck. Its sort of like trailing, like when you can set your mouse to show its trail that's what the football, tennis balls looks like when viewing on the screen.
The instructions are here...
debug log (wiki)
1.
Enable debugging in Settings>System Settings>Logging,
2.
Restart Kodi
3.
Replicate the problem.
If you are using the Advanced Method ensure you have correctly created and applied the advancedsettings.xml file.
In both instances, you should see the word
DEBUG throughout the log.
Do NOT post your logs directly into the forum. Always use a paste site like pastebin.com. Post the link to your pasted log in the forum
Watching ball sports at 25/30fps?
You may never get good results on crappy hardware like FireTV
What device would you recommend
Reference platform is Linux X11.
(2018-01-16, 10:18)Klojum Wrote: [ -> ]Watching ball sports at 25/30fps?
This ^
What's your source & what fps are the feeds?
