I've recently upgraded to the 3/23 T3CH SVN build. According to some other threads, the switch view in old depreciated skins causes problems. As I still really really want to keep this skin, I'd like to just remove this option from the music and video sections. I've searched the text for 'switch' or 'view' and it's not obvious to me how to remove these items. I would really appreciate some assistance, as I want to prolong the life of this great skin for me.
thanks!
I just built a new one from the SVN and I'm not seeing that button in those screens at all care to screenshot it ? incase i'm confused
Man I wish I didn't look into this.
Look what you made me do in the SVN and I'm still not finshed
Quote:Revision: 1352
Author: jezz_x
Date: 3:01:56 PM, Monday, 21 April 2008
Message:
Fixed : the default label
Modified : /Project Mayhem II/PAL/Defaults.xml
Modified : /Project Mayhem II/PAL16x9/Defaults.xml
Quote:Revision: 1353
Author: jezz_x
Date: 3:16:32 PM, Monday, 21 April 2008
Message:
Fixed : 16x9 didn't have a default radio button for non checked
Changed : Removed font files for resolutions because XBMC auto font scaling does a much better job these days
Deleted : /Project Mayhem II/1080i/Font.xml
Deleted : /Project Mayhem II/720p/Font.xml
Deleted : /Project Mayhem II/NTSC/Font.xml
Deleted : /Project Mayhem II/NTSC16x9/Font.xml
Quote:Revision: 1354
Author: jezz_x
Date: 5:22:15 PM, Monday, 21 April 2008
Message:
Chnaged : Cleaned up the code a bit and removed duplicate files no longer needed
Fixed : 16x9 home screen media overlays
Fixed : Images in lower right of Media Windows
Modified : /Project Mayhem II/PAL/DialogFavourites.xml
Modified : /Project Mayhem II/PAL/Home.xml
Modified : /Project Mayhem II/PAL/MyGameSaves.xml
Modified : /Project Mayhem II/PAL/MyMusicNav.xml
Modified : /Project Mayhem II/PAL/MyMusicPlaylist.xml
Modified : /Project Mayhem II/PAL/MyMusicSongs.xml
Modified : /Project Mayhem II/PAL/MyPics.xml
Modified : /Project Mayhem II/PAL/MyPrograms.xml
Modified : /Project Mayhem II/PAL/MyScripts.xml
Modified : /Project Mayhem II/PAL/MyVideo.xml
Modified : /Project Mayhem II/PAL/MyVideoNav.xml
Modified : /Project Mayhem II/PAL/MyVideoPlaylist.xml
Modified : /Project Mayhem II/PAL/ProfileSettings.xml
Modified : /Project Mayhem II/PAL/Settings.xml
Modified : /Project Mayhem II/PAL/SettingsCategory.xml
Modified : /Project Mayhem II/PAL/SettingsProfile.xml
Modified : /Project Mayhem II/PAL/SettingsSystemInfo.xml
Modified : /Project Mayhem II/PAL/includes.xml
Deleted : /Project Mayhem II/PAL16x9/DialogContentSettings.xml
Deleted : /Project Mayhem II/PAL16x9/Home.xml
Deleted : /Project Mayhem II/PAL16x9/MyGameSaves.xml
Deleted : /Project Mayhem II/PAL16x9/MyMusicNav.xml
Deleted : /Project Mayhem II/PAL16x9/MyMusicPlaylist.xml
Deleted : /Project Mayhem II/PAL16x9/MyMusicSongs.xml
Deleted : /Project Mayhem II/PAL16x9/MyPics.xml
Deleted : /Project Mayhem II/PAL16x9/MyPrograms.xml
Deleted : /Project Mayhem II/PAL16x9/MyScripts.xml
Deleted : /Project Mayhem II/PAL16x9/MyVideo.xml
Deleted : /Project Mayhem II/PAL16x9/MyVideoNav.xml
Deleted : /Project Mayhem II/PAL16x9/MyVideoPlaylist.xml
Deleted : /Project Mayhem II/PAL16x9/MyWeather.xml
Deleted : /Project Mayhem II/PAL16x9/ProfileSettings.xml
Modified : /Project Mayhem II/PAL16x9/Settings.xml
Deleted : /Project Mayhem II/PAL16x9/SettingsCategory.xml
Deleted : /Project Mayhem II/PAL16x9/SettingsProfile.xml
Deleted : /Project Mayhem II/PAL16x9/SettingsSystemInfo.xml
Deleted : /Project Mayhem II/PAL16x9/Startup.xml
Modified : /Project Mayhem II/media
Deleted : /Project Mayhem II/media/16x9home-myfiles.png
Deleted : /Project Mayhem II/media/16x9home-mymusic.png
Deleted : /Project Mayhem II/media/16x9home-mypictures.png
Deleted : /Project Mayhem II/media/16x9home-myprograms.png
Deleted : /Project Mayhem II/media/16x9home-myvideos.png
Deleted : /Project Mayhem II/media/16x9home-myweather.png
Deleted : /Project Mayhem II/media/16x9home-settings.png
Thanks Jezz_X you rock!!!
I'll update the skin from SVN tonight and let you know if this solves my problem!!!
thanks again!!!!!
Oops, I read your post more carefully and see that there is still some updating to do. I hope it's not asking too much. Thanks again.
well your issue should be gone but there are a couple of others I want to do as well
