Full Version: No sound - kodi on android tv
Good evening, I recently bought a ElectriQ 50" android TV so I could install kodi for my boys and me instead of using our ( out old date) mx boxes....
Now we get sound on the TV when using the Xbox.... We get sound on the TV when we are watching showbox but got the love of me I can't figure out why sound isn't working on kodi :'( this was the main reason we bought the Damn TV lol...
Can anyone guide me without the' have you tried turning it off and on again '? Haha
I don't need to change my audio cables as they work fine with the TV... I've already uninstalled and reinstalled kodi to see if that makes a difference.... Selected and deselected' pass through '.... I'm genuinely stumped Sad....
I would really really appreciate anyone's help xx
Kttyn
The instructions are here... debug log (wiki)
1.Enable debugging in Settings>System Settings>Logging,
2.Restart Kodi
3.Replicate the problem.
If you are using the Advanced Method ensure you have correctly created and applied the advancedsettings.xml file.
In both instances, you should see the word DEBUG throughout the log.
Do NOT post your logs directly into the forum. Always use a paste site like pastebin.com. Post the link to your pasted log in the forum
Dont ask how this works or why it works with this tv but after a bit of trying everything this worked for me,
First of all uninstall your kodi then on your tv go to your browser and put this in and install it
http://mirrors.kodi.tv/releases/android/...bi-v7a.apk
its a link for kodi 16.1 Jarvis
after install open it wait until everything loads then close it
go to google play app find kodi and then update
You will now have 17.6 with sound.
I hope this helps.
Sorry but that's just a stupid advice. You might as well install v17 straight away
Dont be stupid,
Thats where the problem lays it only works if you update it from 16.1  Rolleyes
Bullshit
Have you got an ElectriQ tv?
