Full Version: Should scrapper work?
Should scrapper work now? In my situation is doesn't find anything.
It looks like scrapper isn't even try to loop through folders. It ends after 0.3s.
Kodi 16 on AppleTV (OSMC) with similar settings can scan content, so file structure should be fine. Diffrence is SMB.
Log is from PC UWP, but XONE behave the same.
01:13:13.251 T:11416   DEBUG: ------ Window Init (Pointer.xml) ------
01:13:14.894 T:11416   DEBUG: Unfocus WindowID: 10025, ControlID: 50
01:13:14.934 T:11416   DEBUG: CInputManager:TonguerocessMouse: trying mouse action rightclick
01:13:14.946 T:11416   DEBUG: URIUtils::IsOnDVD is not implemented
01:13:14.953 T:11416   DEBUG: CAddonSettings[metadata.themoviedb.org]: loading setting definitions
01:13:14.953 T:11416   DEBUG: CAddonSettings[metadata.themoviedb.org]: trying to load setting definitions from old format...
01:13:14.954 T:11416   DEBUG: CAddonSettings[metadata.themoviedb.org]: loading setting values
01:13:14.954 T:11416   DEBUG: ------ Window Init (DialogContextMenu.xml) ------
01:13:16.722 T:11416   DEBUG: Unfocus WindowID: 10106, ControlID: 1007
01:13:16.722 T:11416   DEBUG: Unfocus WindowID: 10025, ControlID: 50
01:13:16.737 T:11416   DEBUG: CInputManager:TonguerocessMouse: trying mouse action leftclick
01:13:16.941 T:11416   DEBUG: ------ Window Deinit (DialogContextMenu.xml) ------
01:13:16.957 T:11416   DEBUG: CAddonSettings[metadata.themoviedb.org]: loading setting definitions
01:13:16.957 T:11416   DEBUG: CAddonSettings[metadata.themoviedb.org]: trying to load setting definitions from old format...
01:13:16.957 T:11416   DEBUG: CAddonSettings[metadata.themoviedb.org]: loading setting values
01:13:16.971 T:11416   DEBUG: ------ Window Init (DialogExtendedProgressBar.xml) ------
01:13:16.977 T:16476  NOTICE: VideoInfoScanner: Starting scan ..
01:13:16.978 T:19432   DEBUG: CAnnouncementManager - Announcement: OnScanStarted from xbmc
01:13:16.978 T:19432   DEBUG: GOT ANNOUNCEMENT, type: 16, from xbmc, message OnScanStarted
01:13:17.003 T:16476   DEBUG: CAddonSettings[metadata.themoviedb.org]: loading setting definitions
01:13:17.003 T:16476   DEBUG: CAddonSettings[metadata.themoviedb.org]: trying to load setting definitions from old format...
01:13:17.003 T:16476   DEBUG: CAddonSettings[metadata.themoviedb.org]: loading setting values
01:13:19.986 T:16476   DEBUG: VideoInfoScanner: Scanning dir 'sftp://USERNAME:[email protected]:22/D:/Movies/' as not in the database
01:13:20.040 T:16476   DEBUG: VideoInfoScanner: No (new) information was found in dir sftp://USERNAME:[email protected]:22/D:/Movies/
01:13:20.302 T:16476  NOTICE: VideoInfoScanner: Finished scan. Scanning for video info took 00:03
01:13:20.302 T:19432   DEBUG: CAnnouncementManager - Announcement: OnScanFinished from xbmc
01:13:20.302 T:19432   DEBUG: GOT ANNOUNCEMENT, type: 16, from xbmc, message OnScanFinished
01:13:20.308 T:11416   DEBUG: URIUtils::IsOnDVD is not implemented
01:13:20.309 T:11416   DEBUG: CGUIMediaWindow::GetDirectory (sources://video/)
01:13:20.309 T:11416   DEBUG:   ParentPath = [sources://video/]
01:13:20.309 T:11416   DEBUG: URIUtils::IsOnDVD is not implemented
01:13:20.399 T:22880   DEBUG: Thread BackgroundLoader start, auto delete: false
01:13:20.420 T:22880   DEBUG: Thread BackgroundLoader 22880 terminating
01:13:20.794 T:11416   DEBUG: ------ Window Deinit (DialogExtendedProgressBar.xml) ------
01:13:21.760 T:11416   DEBUG: ------ Window Deinit (Pointer.xml) ------
01:13:23.022 T:11416   DEBUG: Keyboard: scancode: 0x38, sym: 0x0000, unicode: 0x0000, modifier: 0x100
01:13:23.022 T:11416   DEBUG: CInputManager::HandleKey: alt-164 (0x4f0a4, obc-323493) pressed, action is
01:13:23.252 T:11416   DEBUG: CWinEventsWin10::OnWindowActivationChanged: window is active
01:13:23.963 T:11416   DEBUG: CWinEventsWin10::OnVisibilityChanged: window is hidden
We need the full log. Please post the full log at https://pastebin.com/ or https://paste.ubuntu.com/ and remove the snippet from your post
I think "Scan recursively" doesn't work for SSH. Subfolders aren't visible.
If I move mp4 file directly to main folder, then it can be find.
Stable Kodi 17.6 on Android has same bug, so probably it's general issue, not only uwp.
https://pastebin.com/tAPYBuLm
Workaround:
-for movies use flat folder structure
-for TV shows add every show as single source, because Kodi don't support the flat folder structure for multiple TV Shows
