(2019-02-25, 11:03)IgaBiva Wrote: [ -> ]So there will be no workaround for this?
After all, it seems that XBOX will not be my media center of choice
Report it to the Xbox support team so they can get the driver fixed
You mean directly to Microsoft?
Will do but I do't have high hopes....
I'm not sure but I will try, is there a small example file which doesn't work well?
(2019-02-25, 16:41)IgaBiva Wrote: [ -> ]Will do but I do't have high hopes....
what results of playing problematic video with VLC?
(2019-02-25, 18:08)afedchin Wrote: [ -> ] (2019-02-25, 16:41)IgaBiva Wrote: [ -> ]Will do but I do't have high hopes....
I have tested only 3 files, same as in log from my previous post.
Actually, results are same. Video which works with Kodi works with VLC and ones which don't work in Kodi don't also work in VLC. Only difference is that Kodi handles files a bit better - more FPS and in VLC is everything distorted.
I have sent you PM with sample videos, 30 seconds of 2 problematic files.
Thank you for your efforts.
