Full Version: DialogKeyboard.xml
I am trying to make the DialogKeyboard.xml dialog, but opening the window keeps crashing Kodi. The debug log does not give much away, the last lines being the following:
14:39:29.597 T:139890445572480   DEBUG: Activating window ID: 10103
14:39:29.597 T:139890445572480   DEBUG: ------ Window Init (DialogKeyboard.xml) ------
14:39:29.597 T:139890445572480    INFO: Loading skin file: DialogKeyboard.xml, load type: KEEP_IN_MEMORY
--> Crash
Does the dialog need certain controls for being able to open, or should it work like other dialogs, and thus being a problem in my xml?
Thanks,
I figured it out.
The window needs the edit control (id: 312), it works now Blush
Thread marked solved.
