2022-01-06, 05:59
The automatic update option? Currently it doesn't work and in fact I don't think it even worked in the original repository, I think the service needed to work hadn't been implemented at the time.
(2022-01-06, 17:35)jokerigno Wrote: [ -> ]It is in your roadmap?
It will be great to all the series (hawkeye) that release an episode a week.
(2022-03-09, 19:45)chaos83 Wrote: [ -> ]Hello, I am trying to add TV shows to the library. For example, the name of the show is "The name of the show S01E05". Unfortunately, the shows are not added even though an ID is included.As I recall this is part of the original v4.x.x implementation.
The whole thing should be processed somewhere in one of the files under "Addons\script.library.integration.tool\resources\lib\items".
In the "episode.py" I saw that this is checked with the following "re.match('.*[0-9]x[0-9].*|.*[Ss][0-9].*[Ee][0-9].*', self.clean_title):".
What do I need to change to make this work?
(2022-03-10, 01:03)chaos83 Wrote: [ -> ]Yes, I have already tried to adjust that. But it doesn't really work.
Can't be anything big, can it? Can you maybe take a look at it?
It detects this, but whether it actually works is another story: The name of the show S01E05.python:re.match('.*[0-9]x[0-9].*|.*[Ss][0-9].*[Ee][0-9].*', self.clean_title):
(2022-04-24, 11:23)Trillian_M1 Wrote: [ -> ]Hey kingkiller, great addon and i enjoy using it in my setup. However I was just wondering if you have any plans to include video addons like 3sat Mediathek, ARD Mediathek, ZDF Mediathek and addons like them. Thanks
(2022-06-05, 11:55)mthawk Wrote: [ -> ]Any plans to add YouTube as supported ? As well as Audio plugins ?
(2022-06-05, 11:55)mthawk Wrote: [ -> ]@Lunatixz had a good plugin PseudoLibrary in the past which was literally supporting any audio/video plugin, but after migration to Kodi 19 with Python 3 old one unfortunately not supported so i am looking for alternatives.
(2022-06-05, 18:42)kingkiller Wrote: [ -> ]What youtube addon are you using?YouTube 6.8.18+matrix.1 by anxdpanic & bromix from Kodi Addon Repo http://download.osmc.tv/kodi/addons/matr...o.youtube/
(2022-06-10, 15:46)mthawk Wrote: [ -> ]Hello.
I am not a python guy, however long time ago i had to make small changes to @Lunatixz 's PseudoLibrary to make it work as i wanted
But adaptation of python 2.x plugin to 3.0 seems not to be possible to me
May be someone could take a look on PseudoLibrary's code and think is it worth to re-write for python 3.x
