Full Version: Can't access USB Storage on Xbox One Without Internet
I don't know if this has already been discussed already, but I can't access USB storage in KODI on Xbox One if there is no internet connection available. Just want to know if there is a workaround in place.
I can confirm this.  I was thinking maybe kodi on the xbox one access the usb ports via a network address.  So when the network is turned off the usb ports aren't available?
I was wondering if this was a limitation of UWP?  It seems when accessing the usb storage it takes a couple of seconds to open a media file.  Other apps on the Xbox seem to access the files directly.
My understanding is there was an error in the implementation, and that this has now been fixed, so you should see correct operation whenever the next test build gets pushed to users.
@jjd-uk is right, the issue has been fixed and will not exist in next build
