Hi Tomas,
Can you also please add my email to your Alexa Skill beta? It's
[email protected].
Paul
Hi Tomas,
[email protected].
Paul
Can I get an add to the Alexa skill please.
Hi Tomas,
Just recently the skill is returning a max of 10 movies when i ask for "show comedy movies" or "show movies with 'actor'". Should I be seeing all of the movies that fit or is there a new limitation?
Hi Tomas,
[email protected]
Paul
Hello @
tkislan
I would love to test this skill, please add me.
Thank you!
(2018-08-14, 18:05)hslansky Wrote: [ -> ]Hi Tomas,
It was always limiting it to 10 movies. So that they all fill into the screen, and you don't have to scroll.
Thank you, I really looking forward to test this.
Thanks, Tomas,
Much appreciated!
Paul
(2018-07-25, 18:29)tkislan Wrote: [ -> ]Quote:If I go to the Kodi connect website it is secure. However the IP address https://46.101.194.37/ the app is using to connect is showing as unsecure from chrome browser for some reason
Because certificate is always issued to domain, no to IP address.
Kodi connect addon is actually using a normal hostname to connect to the server, which gets translated to IP address.
But certificate validation should happen against the hostname.
As I said before, there is something wrong with the underlying implementation of network library, which causes this to fail.
Did you guys find any solution to this?
Could you add me dflemi13@ kent.edu without the space?
Thanks,
Scubafossil
Got my 4 kodis all hooked up just waiting on that sweet sweet beta access. dflemi13@
kent.edu
