Having the same issue PMing you as others. I think you added me a couple months back but for whatever reason when I went to re-add it this morning it said that I don't have access anymore.
[email protected]
Hi you could also give me access to Kodi Connect have already set up everything just waiting for access to the skill.
[email protected]
Hi
I know you added me before, but now *cheers to me* italian language is coming for alexa.
Since Italian was activated on the app i m no longer able to see the skill.
Is it language restricted?
Thank you
He has not been online for a long time, maybe he is on vacation. Is the skill if tkislan the enrollment directly Active or you still have to search it?
Is this skill still being supported? If so, I'd like to be invited to the Beta. I can't send you a PM, but my email is:
christopher.hendrix.1970 AT gmail.com
Good morning
I would love to use this skill, but are you going to support several languages as Spanish?
If you need a Beta Tester in Spanish, let me know.
Thank you and Greetings,
Just missing the skill. Put me in the queue please. Thanks.
Email :
[email protected]
Edit: Email updated.
Hi it doesn't seem to be letting me PM you either
can I be added to the beta
[email protected]
many thanks
Hi! Same here, I'm not authorized to send you a PM.
Would be great if I can be added to the Beta.
nonootje "at" gmail "dot" com
Tyvm!
Can you add our alexa please?
Lareina.zen "at" ntlworld "dot" com
Hey this looks great any chance I could get in on the Beta
I am actually a software tester by trade !!
[email protected]
This skill is really amazing!
I do however encounter one issue...
The skill works great on my kodi instance running on a windows PC.
It does however not work with my LibreElec Kodi instance.
When you say something - it does get acknowlegded, but nothing happens.
Sometimes a pop-up shows up "Kodi Connect - Connected" and then "Kodi Connect - Disconnected"
Anybody experience with this?
