Full Version: Move 'Record all' to top / default
Hello,
Is there a way to configure the timer type to be 'Record all' by default? We either press record on the EPG to record a single show, or pull up 'add timer' to record a series, but every time have to change the type to 'Record all'.
Would be much easier for the family to set up series recordings if I could change the default valve to record all?
Could this be done via some recording template set up or is it a code change?
