I added several movies to my library today. TMDB scraper worked fine except the ratings didn't show up. It worked fine for me last week. Is it just me?
Thanks for everything guys, Matt.
Chances are close to 100% it is only you.
...but we can't help you. We don't know what OS/ Kodi version/ Scraper version with what scraper setttings/ which skin you are using and also no debug log.
So in order to provide you some support, I hope you do appreciate we need some details.
I'm using OS X 10.7.5, KODI 16.1, TMDb v.4.1.1, Confluence skin, Media info 2 view. The scraper's set to get the ratings from TMDb.
I removed the movie eXistenZ, then put it back and scraped again for the debug log. Hope this helps, thanks.
https://paste.ubuntu.com/26466846/
Yes, definitely helped. This is exactly what we need. Fix will be pushed in few hours.
Thank you!
Great news, thanks again!
Works great. I rate it 10 out of 10
