Full Version: Xbox one
I have a xbox one and I got kodi a fell days ago,
I'm trying to watch tv on it, but I'm putting the m3u links and is not working,
so I get a pendrive and load the m3u file local in xbox, it makes the channels apper on kodi then not load.
So i tried the same at cellphone android and it works.
Please help me
The instructions are here... debug log (wiki)
1.Enable debugging in Settings>System Settings>Logging,
2.Restart Kodi
3.Replicate the problem.
If you are using the Advanced Method ensure you have correctly created and applied the advancedsettings.xml file.
In both instances, you should see the word DEBUG throughout the log.
Do NOT post your logs directly into the forum. Always use a paste site like pastebin.com. Post the link to your pasted log in the forum
