Full Version: Search pvr guide pre settings
Hello,
i would like to report an issue when i search in pvr guide. Don't know if it is pvr addon or kodi related issue.
While start date show correct current date, the end date is usually wrong. Today the 27.01. I have epg data until 09.02. In pvr settings i select show 14 days. But the kodi pre selected end date show 06.02.18.
And as second issue the start date and end date should be empty or have 24 hours period. Now i see start time 09.22 am and end time 10.22 am. Only search within one hour is needless. So everytime i have to delete both start and end times and the end date.
At least i would like to ask for a request that the search direct begin after press enter tab. Actually a new window open with keyboard controls.
Thanks in advance.
You found a bug. ;-)
Thank you Smile
There is one more thing. When reset search settings the start time is 06:00 and end time is 00:15. I am looking for full 24h search time by default.
(2018-02-06, 19:36)tehax Wrote: [ -> ]There is one more thing. When reset search settings the start time is 06:00 and end time is 00:15. I am looking for full 24h search time by default.
Then, you won't get what you're looking for. Preset range is from date and time of the earliest event in your epg to date and time of the latest event in your epg. Means, whole epg will be searched time wise, which makes perfect sense for a default.
Ah, i don't know that time settings are for complete epg range Tongue ​.I thought it stand for 24h/day time window.
(2018-02-06, 19:46)tehax Wrote: [ -> ]Ah, i don't know that time settings are for complete epg range Tongue ​.I thought it stand for 24h/day time window.
Sigh, "thinking" users.
I think there there is still a bug in pre settings. A standard active pre setting is "ignore present timers", but the opposite is the result. I does not ignore timers. Still when i disable that setting then present timers will be ignore. Or am i wrong?
(2018-02-22, 23:56)tehax Wrote: [ -> ]I think there there is still a bug in pre settings. A standard active pre setting is "ignore present timers", but the opposite is the result. I does not ignore timers. Still when i disable that setting then present timers will be ignore. Or am i wrong?
Just checked. Works here (18 nightly).
