Full Version: Sony Android TV - Stuttering and no audio to play 4K videos
Hello all,
I've been trying to play some 4K videos (Bitrate around: 50 Mbps) in Kodi (HW: Sony Android TV X750D) but most of the time it starts stuttering and after that with no audio anymore. In general, the video doesn't play smooth.
So far, I tried the changes below in Kodi and Tv, but no success yet.
1 - TV Factory Reset
2 - Changed cache in many different ways (buffermode, memorysize and readfactor)
3 - In Video processing, disabled H/W acceleration in the following ways:
  - Mediacodec and Mediacodec (surface) -> Video plays really slow (impossible to watch)
  - Mediacodec (surface) -> Video plays really slow (impossible to watch)
  - Mediacodec -> Video plays smooth but it start stuttering at some moments and get out of audio
Network setup I tried:
1 - Video source device and Tv in ethernet cable 1 Gbps (Even though TV has only 100Mbps ethernet port)
2 - Video source in ethernet cable and TV connected in the network with a 802.11ac (1900)
Conclusion: In both setup, the video source device is sending/receive 70Mbps in average when playing the videos.
I enabled Kodi's log and see that in average (during the video playblack) it's been using 400MB RAM and 115% (Kodi CPU).
Logs:
MemoryCacheEnabled: https://ufile.io/4hmvm
DiskCacheEnabled: https://ufile.io/2uy8g
Factory Config: https://ufile.io/bnbsf
PS: SOrry for not using pastbin but logs are bigger than 'free' option can handle.
TV Specs:
Model: Sony 65X750D (https://www.rtings.com/tv/reviews/sony/x750d)
Specs: 2GB RAM, 8GB Disk and 4 CPUs.
Example of Video Tested
 Video
 Format                                   : HEVC
 Format/Info                              : High Efficiency Video Coding
 Format profile                           : Main [email protected]@[url=https://forum.kodi.tv/member.php?action=profile&uid=232430]high[/url]
 Codec ID                                 : V_MPEGH/ISO/HEVC
 Duration                                 : 1 h 43 min
 Bit rate                                 : 52.7 Mb/s
 Width                                    : 3 840 pixels
 Height                                   : 2 160 pixels
 Display aspect ratio                     : 16:9
 Frame rate mode                          : Constant
 Frame rate                               : 23.976 (24000/1001) FPS
 Color space                              : YUV
 Chroma subsampling                       : 4:2:0 (Type 2)
 Bit depth                                : 10 bits
 Bits/(Pixel*Frame)                       : 0.265
 Stream size                              : 38.3 GiB (72%)
 Default                                  : Yes
 Forced                                   : No
 Color range                              : Limited
 Color primaries                          : BT.2020
 Transfer characteristics                 : SMPTE ST 2084
 Matrix coefficients                      : BT.2020 non-constant
 Mastering display color primaries        : R: x=0.680000 y=0.320000, G: x=0.265000 y=0.690000, B: x=0.150000 y=0.060000, White point: x=0.312700 y=0.329000
 Mastering display luminance              : min: 0.0050 cd/m2, max: 4000.0000 cd/m2
 Maximum Content Light Level              : 6414 cd/m2
 Maximum Frame-Average Light Level        : 952 cd/m2
How can I know if the hardware (TV) is being the bottleneck and has resources (CPU/MEM) enough to play those kind of videos?
Sincerely,
Hello,
Please, is anyone able to tell anything about the logs that could matter to the issue? I checked it many times but I don't know which errors/warnings could be related to the issue.
I really appreciate any help here.
Thanks,
Rafael Boschini
(2018-01-28, 15:56)rafaboss Wrote: [ -> ]TV connected in the network with a 802.11ac (1900)
Just wondering... Does the TV also have a ethernet cable option? Wifi can be suffering from signal loss at the weirdest moments.
Start with playing simpler video files. If the big(ger) files have a problem, it'll be a network problem IMO.
Also try other/simpler 4K testvideos (lower bitrate). Just maybe it is a codec problem.
Quote:NOTICE: Disabled debug logging due to GUI setting. Level 0.
Always enable debugging for more detailed log files.
Quote: DEBUG: ffmpeg[8C5DB920]: [matroska,webm] Non-increasing DTS in stream 2: packet 1489 with DTS 1242, packet 1490 with DTS 124
Lots of these... Audio was incorrectly muxed? I'm no audio expert, though.
For uploading longer log files, try https://paste.ubuntu.com .
PS: with large log sections being identical, you can remove the majority of sections section. Just clearly indicate it.
Check this out. Sony ATV network performance is just bad. Either try Ethernet cable or move closer to the access point.
