2018-01-31, 01:08
wich skins supports adding widgets to the submenu?
i only see one skin that can do this, skin fuse neuse.
but its a creat skin but list content is to small, and de modded version fuse shifted i dont like.
i did litle reseach to make my own mod onder nox silvo, but it will not work, i cann add the widgets now in the submenu cuustomizer (under the main menu customizer click manage submenu and then select widget 1 or 2)
the witgets will not display in de skin, because i think its litle difficult, proberly i also must do edits in the main.xml, or other file to let is show on my screen.
