(2020-01-22, 08:00)M89SE Wrote: [ -> ]Hi Emil,
I'm a developer for the m-TVGuide addon, and as I find it very interesting I would like to implement C More as a TV service provider in such way I've done with other polish providers (Cyfrowy Polsat GO, nc+ GO) by modifying your code, and I wonder if you don't mind?.
BR
Mariusz
mods-kodi
Hi!
Sure, as long as you comply with the MIT License I'm completely fine with it. It is open source after all! :-)
(2020-01-22, 10:24)emilsvennesson Wrote: [ -> ] (2020-01-22, 08:00)M89SE Wrote: [ -> ]Hi Emil,
BR
Mariusz
mods-kodi
Hi!
Yes, of course I'll follow the MIT License. I understand that it's open source but I think you should always respect someone's work, after all it's no harm in just asking, thank you.
emilsvennesson Are you planning to fix login for operator such as Telia provider? As now I'm only getting standard cmore login to work in my addon.
(2020-02-15, 11:43)M89SE Wrote: [ -> ]@emilsvennesson Are you planning to fix login for operator such as Telia provider? As now I'm only getting standard cmore login to work in my addon.
I don't have an account and limited time to work on this. You can send me a PM with account details and I'll take a look if it's something that can be fixed relatively easy.
(2020-02-15, 14:53)emilsvennesson Wrote: [ -> ] (2020-02-15, 11:43)M89SE Wrote: [ -> ]@emilsvennesson Are you planning to fix login for operator such as Telia provider? As now I'm only getting standard cmore login to work in my addon.
I've sent you a PM. Thank you!
Tried this addon today, and just get "error check logs"
checking the logs :
020-09-22 11:04:58.548 T:140360217302784 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <class 'requests.exceptions.ConnectionError'>
Error Contents: HTTPSConnectionPool(host='account.cmore.se', port=443): Max retries exceeded with url: /session?client=cmore-android&legacy=true (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x7fa8487082d0>: Failed to establish a new connection: [Errno -2] Name or service not known',))
File "/home/mrpg/.kodi/addons/plugin.video.cmore/default.py", line 5, in <module>
addon.run()
File "/home/mrpg/.kodi/addons/plugin.video.cmore/addon.py", line 14, in run
router(sys.argv[2][1:]) # trim the leading '?' from the plugin call paramstring
File "/home/mrpg/.kodi/addons/plugin.video.cmore/addon.py", line 398, in router
if helper.check_for_prerequisites():
File "/home/mrpg/.kodi/addons/plugin.video.cmore/resources/lib/kodihelper.py", line 88, in check_for_prerequisites
if self.set_locale(self.get_setting('locale')) and self.set_login_credentials() and self.check_for_credentials():
File "/home/mrpg/.kodi/addons/plugin.video.cmore/resources/lib/kodihelper.py", line 118, in check_for_credentials
self.login_process()
File "/home/mrpg/.kodi/addons/plugin.video.cmore/resources/lib/kodihelper.py", line 125, in login_process
self.c.login(username, password, operator)
File "/home/mrpg/.kodi/addons/plugin.video.cmore/resources/lib/cmore.py", line 182, in login
credentials = self.make_request(url, method, params=params, payload=payload)
File "/home/mrpg/.kodi/addons/plugin.video.cmore/resources/lib/cmore.py", line 70, in make_request
req = self.http_session.post(url, params=params, data=payload, headers=headers)
File "/home/mrpg/.kodi/addons/script.module.requests/lib/requests/sessions.py", line 581, in post
return self.request('POST', url, data=data, json=json, **kwargs)
File "/home/mrpg/.kodi/addons/script.module.requests/lib/requests/sessions.py", line 533, in request
resp = self.send(prep, **send_kwargs)
File "/home/mrpg/.kodi/addons/script.module.requests/lib/requests/sessions.py", line 646, in send
r = adapter.send(request, **kwargs)
File "/home/mrpg/.kodi/addons/script.module.requests/lib/requests/adapters.py", line 516, in send
raise ConnectionError(e, request=request)
ConnectionError: HTTPSConnectionPool(host='account.cmore.se', port=443): Max retries exceeded with url: /session?client=cmore-android&legacy=true (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x7fa8487082d0>: Failed to establish a new connection: [Errno -2] Name or service not known',))
it seems it tries to contact account.cmore.se , this does not seem to be a valid url (ing: account.cmore.se: Name or service not known)
please can you look at this issue?
Best Regards
Patric
(2020-09-22, 11:11)mrpg Wrote: [ -> ]Tried this addon today, and just get "error check logs"
checking the logs :
addon.run()
Best Regards
Patric
Hi!
+1 on the above issue. Got the exact same problem. The log seems to be the same as well.
Help is much appreciated!
Thank you
Regards
Nils
Is it any Kodi19 version available for Cmore addon? Or will it be created?
Thanks for great work
Kristian
