Is it possible to force change a tv show's network? For example I have shows that were on spike but not that spike is paramount any new shows will be paramount. So I would like to change all tv shows that are on spike tv network to paramount. is that possible?
If you mean the metadata for it, then only by either using a local
NFO (wiki) file for each or by an alteration to the database that the scraper you're using is pulling from.
For the latter you'd need to see which scraper you're using, log into their website, get an account there and either change it or ask on their forums for the change. Whether it would be done or not is another question though...
