Full Version: Can you have Channel Selection in Live TV automatically switch to the channel?
I find that when in the Live TV Guide and I select a channel, I then have to select Switch in order to change the channel.
Is there something in settings I can change to automatically switch to the channel when selecting the a channel in
the TV Guide?
It depends on Kodi. Not on the skin.
Tgx
(2018-02-04, 17:59)tphillip1120 Wrote: [ -> ]I find that when in the Live TV Guide and I select a channel, I then have to select Switch in order to change the channel.
the TV Guide?
Yes, there is a Kodi setting for defining what happens when you select an event in the epg grid.
Where can I find it in your skin. I know where the setting is in the kodi default skin.
I have looked every where for it.
Settings/PVR & Live TV/Guide/Default select action.
Change to "Switch to channel".
