2018-02-10, 02:05
2018-02-10, 02:53
There is/was this addon: https://forum.kodi.tv/showthread.php?tid=179036
Obtaining the caller id is likely to be the biggest hurdle, and how you overcome it will depend entirely on your phone system.
Once you have the caller id you can use
Searching the forum for "caller id" brings up a number of hits, including: https://forum.kodi.tv/showthread.php?tid=308531
kodi-send --action="Notification(Caller is,555-123-456)"
to display a kai toast notification.Searching the forum for "caller id" brings up a number of hits, including: https://forum.kodi.tv/showthread.php?tid=308531
2018-02-11, 14:27
There is also Yatsee
https://play.google.com/store/apps/detai...free&hl=en
Just download the addon after you install the remote
https://play.google.com/store/apps/detai...callplugin
if you want it for a cellphone
2018-02-14, 05:33
Thanks works like a charm
