The A-Z tab on the BBC IPlayer no longer displays content to select and play. This the tab where you find past episodes of programs. Anyone have advice how to get this back ?
https://forum.kodi.tv/showthread.php?tid=239378
Please use the thread above for iPlayer WWW. If that's not the add-on you're using then please switch to it.
Also make sure you're up to date with the install, as the BBC recently changed some things so only the current version works correctly. See the thread above for details.
Thread closed.
